Configures the router discovery advertisements to send only with VRRP link local address on the VRRP-enabled VLAN interface.
| vlan_name | Specifies an IPv6 configured VLAN. |
| router-discovery | IPv6 Router Discovery configuration |
| ipv6 | IPv6 Router Discovery configuration. |
| vrrp-lla-only | Router advertisement is sent only with VRRP‘s virtual link local address. |
| on_off | Specifies setting the flag to on or off. Default is off. |
Default is off.
This command configures the router advertisements to use only VRRP‘s link local address and avoid VLAN link local address on VRRP-enabled VLAN interfaces.
When set to on, VRRP‘s link local address is used in router advertisements. If this command is not entered, the default value is off and VLAN link local address is used in router advertisements.
You need to explicitly set this value to "off" when VRRP is disabled on the VLAN.
# configure vlan top_floor router-discovery vrrp-lla-only on
This command was first available in ExtremeXOS 33.1.1.
This command is available on all platforms that support the Advanced Edge License as shown in the Switch Engine v33.1.1 Licensing Guide document.
